Another SE/30... Y1 resistor (?)
That's a nice early-ish production SE/30 board.
Cleaning: Never had to deal with battery corrosion like this, but if it helps, what I do is... I spray boards with foaming industrial Simple Green (no coloring), let it sit for ten minutes, rinse under a faucet for sheeting action, then pour about a 1/4-1/2 gallon of distilled water on it, then rinse with 99% isopropyl. Everyone has their own method. Mine is based mostly on economy, you ideally shouldn't rinse a PCB under a faucet, but my hope is that the relatively cheap distilled water chased by alcohol pushes away most of the crap from the tap water because I don't let the tap water rest on the board. I can attest to this method working very well so far on about ten Macs and about as many Tek scopes, but again, I've never had to deal with that level of battery corrosion. The vinegar sounds good though, I may experiment with that.
Back to your board, if it was the later bright green version with white plastics, I'd pass on this much work trying to revive it. The one you have is a much more sturdy board and more likely to suffer the cleaning that you're doing.
Thanks a lot.  I have 91% Isopropyl, which I'd been using.  I take your point about distilled water.  I wasn't so diligent with the board (I'll post updated pics in a day or two).  I had been using tap water (this is my first experiment and I got the SE/30 precisely for this reason [my SE is entirely original except for the miniscribe and I suspect it'll eventually need service]).
I've been cleaning the casing of my Powerbook 5300c battery also and I suspect (per Unity's notes also) that the continued presence of what I think is something related to corrosion is because of the use of tap water.  Though it may just be discoloration.
I did another pass at the logic board today.  I desoldered the battery holder.  Honestly the board might be unsalvageable but I think the physical damage is minimal.  However, at the moment it's missing a few components - Y1 (that piezzo), D1 and possibly D2 and C12.  Anyway, out of curiosity I hooked it all up and turned it on.  I also put a floppy in because I think the HD might be dead.  It wasn't initializable inside my 7100/66 but the terminator resistors might have burned out or something.
The floppy drive makes a short single sound (like a writing sound) which I assume just means power is flowing to the bus (or whatever it's called).  The screen doesn't come on and it won't eject the disk which suggests it's not getting to the ROM.  I took out the smaller 4 of the 8 RAM SIMMS to no effect.
Okay I was typing this message while debugging.  I accidentally hit the CRT control board and popped the little glass nub.  That triggered a gas-rushing-out sound.  I'm assuming I'm done here... (?)
Having done a little more research: Does anyone have a cheap vacuum sealed neck (I'm not sure if that's what it's officially called) they want to sell?
(or generally am i going to have to buy another, probably unsalvageable, compact mac just for that?)
You need a new CRT monitor, you can't just "reseal" a broken one.
I think someone here on the forums might have a spare for you, but you have to be very careful during the replacement to avoid smashing another one!
Hmm, if you smashed the CRT neck and let the vacuum out, you're really out of luck on that SE/30 :( . You would need a new tube, but you'll also need to replace it and then do an adjustment.
I also been there, done that. You probably left the CRT board on? I did that, so it was really easy to smash it. I was just unplugging a yoke connection or something and when it got loose, my hands flew towards the CRT neck. Sadly it was a very low hours green phosphor XT screen, which is even more rare than a monochrome compact Mac CRT.
Now I ALWAYS take the CRT board off first, before doing any work.
Okay disregard above.  Moving back to the actual topic thread - the SE.  When I turned the board on, nothing unusual happened.  I could hear the floppy power but it couldn't get to the ROM.  That's because the only obviously (and I stress that - obviously) damaged components are D1, Y1, the battery casing, and C12.  Those are all around the ROM and I choose to believe for the moment that that and some lingering acid/corrosion are the primary culprits.
So D1 is some sort of TSM chip... can that be replaced?  Will something like this do for Y1: http://www.amazon.com/32-768KHz-32-768k-Quartz-Crystal-Oscillator/dp/B00NQ8AU30/ref=sr_1_fkmr2_3?ie=UTF8&qid=1423992437&sr=8-3-fkmr2&keywords=piezoelectric+crystal+32.768+kHz? And how do I find just that one capacitor.  Sorry I'm reading our Classicmac2.pdf guide and I just genuinely don't understand.
So this is sort of the current state of that previous corrosion. Let me see if I can do a before-after.
I was also unaware of the need to desocket chips before washing... live and learn... And either I or more likely someone else and possibly also I have corrosion issues with the Video ROM (UK6). I hadn't realized that when the board powered up (which it does) something should have been happening with the (green) screen.
Let me take a slightly different track. What is the bare minimum needed in the way of components - assuming the traces are okay - to get a disk to eject? And to get something to show up on the screen?
I need some baseline debugging environment. [Again, no expert but the traces don't look terrible to me. I also cleaned the vias.]
And: I think if there's a RAM issue, it'd be with SIM 1, where there's still a little corrosion under - I think. Can the screen start without RAM in SIM 1? Can it start without any RAM? It may also be a ROM issue -the ROM looks like it had water spilled on it although I don't know that that did any real damage to the chips or circuit.
Is there really no barebones guide/tutorial for this? For instance... how would I know if the 68030 is fried?
And actually, are there any good guides to dishwashing? I'm probably close to that point. I've used a good deal of vinegar, rubbing alcohol, scrubbing bubbles and distilled water. There are still some problem spots.
This is pushing the edge of my knowledge and probably safety.  I tested the voltage in a few places on the board:
(I didn't control for polarity so I'm just listing voltages)
Disk Port Pins 7/8 - 12V
Pin 5 (the 5V) - Nothing
UK4/6 both 5V
UC8 - 12 V
C1 - 5V
C3 - 5V
C4 - 5V
C5 - 5V
C6 - 0.5V
C7 - 5V
C8 - 5V
C9 - Nothing
C11 - 5V
C12 - Nothing
C13 - Nothing
So unless "nothing" indicates bad trace wires/soldering pads and not busted capacitors, this definitely needs a recap.  The question is is that preventing the screen/ROM from engaging...?
I also pick up voltage (maybe a little less than 5V; at the moment I'm doing this somewhat manually - or digitally in the denotative sense...) at both the RAM and ROM, which is a tentatively good sign.
C9 and C13 are involved in Horizontal Sweep (C12 is also in that circuit - a dampener) I think.  So perhaps their failure prevents the screen from working.  However that shouldn't affect the ROM (?).  I'm concerned that recapping will just give me a blank albeit phosphorescent screen with no processor or ROM activity.
