Anyone want to try one of these SD to CF adapters?NCIX.com and Newegg.ca have been stocking fewer and fewer CF cards though! There may come a time when you need one and there are few to pick from.
I have a copy of FWB HD Toolkit on one of my external drives. I recall running it on my Portable, so maybe its old enough to support 68k machines. I'll have to pull it up and check the version number. Generally the 68k machines don't like SCSI Manager 4.3 drivers. Apple's own docs say you shouldn't even use later versions of Apple HD SC Setup on these machines.Hardware wise I bet it will work fine. Just finding a program to make it be used in an older system may be an issue. When I get some time, I will try again to get mine to work in the 100. It goes sad mac as the HD toolkit is not supported by less than an 030 processor. If silverlining will see it and format it I am in like Flynn.
Hopefully the one from newegg (that I just ordered) will support "True-IDE" mode as well. Am I reading you correctly that this ought to work as a boot drive for the PCMCIA PowerBooks?The auction info says it supports "True-IDE" mode, so it should work in a CF-to-IDE adapter with standard SD storage cards. Don't know about the Wi-Fi part, SDIO is a different beast overall.
You can also use Hard Disk Speedtools 3.6, it only requires System 7 & A Mac SE or above, so it will work with a 68000 processor, and it is far newer than anything else we could use. The last version was released in only November, 2003Hardware wise I bet it will work fine. Just finding a program to make it be used in an older system may be an issue. When I get some time, I will try again to get mine to work in the 100. It goes sad mac as the HD toolkit is not supported by less than an 030 processor. If silverlining will see it and format it I am in like Flynn.
