Have several broken studs on Powerbooks 1xx screen covers.
At some point tried to fix with different methods, so far never worked permanently.
i know a 3D repair file is available but have no access to material.
i tried JB weld or equivalent, super glue…nothing is really bonding to the plastic.
So having nothing to lose really, but having spare parts, i am trying ABS cement for a change.
with an old battery casing and some acetone, mixed both together to get a color matching product.
So far, process is slow, but hardening is there.
Cement is easy to do and cheap.
Will let you know how it works in the end.
