It wouldn't be worth a warning, but it sounds like you might be planning to plug the Mach V processor into the non-Kansas logic board. Probably not a good idea.
I had originally thought about putting the 350mhz card into one of the 300s, generally assuming the 300 would have taxed the motherboard (neglibly) less. I will take a look at part numbers, just so I know what I have but I'll be leaving the 350 on the board it came with.
As for the case swap... I'm not really a fan of the G4 cases... It might be an easier swap, it just has no appeal for me.
Another thought regarding putting the 9600 mobo in a G4 case... Seems counter productive to block PCI slots of a design where one of the biggest pros is the PCI expansion.
Eww. Mainly I'm not confident enough skill to do that. The G4 into 9600 case consists of modifications that aren't externally visible/don't impact the plastic skin.
