Good day,
i have a powerbook 540c and i am thinking of buying a powerbook 145b but the guy that sells it does not know if it works because it has not a power supply to test it.
1) Is powerbook 540c's power supply suitable for powerbook 145b?
2) Does powerbook 145b supports 24-bit addressing mode?
3) My powerbook 540c has a problem with the floppy drive. Can i put and use powerbook 145b's floppy drive on the 540c?
Thanks.
Regards
Dimitris from Greece
Thanks.
Regards
