I can not seem to find any markings on this one. The only "branding" I found was on the SCSI interface board "© 1989 NSI". But its an 030 and the crystal is for 25Mhz with 4MB of RAM. So this appears to be a pretty big upgrade for a 512k. No clue if it would work on a 128k. It only interfaces with the 68000 and taps into the logic cable presumably for some extra power. It can be removed since it attached with the solder-on pin type connection. There are no case labels to indicate upgrade was performed.
