I will add that you must be very careful to never use a disk you intend to boot from on a machine with driver/tools greater than v4.2. You can reinitialize/erase the disk using zip tools v4.2 and restore its ability to be a boot disk however. I'm using the v4.2 Iomega driver even on my OS9 system for this reason. Works just fine. That's an obscure bit of info that you might not run across.
Using a USB zip drive on a Snow Leopard machine is a really easy way to get data onto a vintage Mac. Oh - the drivers on modern OSs (ie non classic Mac OS) won't damage your ability to boot. I'm not sure about HFS file system support on newer versions of X. I might have had to jump through some hoops to make it work on 10.6 even but I don't remember.
Stay far away from drives bigger than 100MB and that say 'parallel port'. If they have a picture of the back of the drive and it has 2 switches it is a SCSI drive. If it has 1 switch it is a zip plus that can do either SCSI or parallel and is safe to use also. If there are NO switches on the back between the connectors then it is a parallel port drive no matter what it is advertised as. If in doubt - ask for a picture of the back of the drive.
Top: SCSI drive (OK)
Middle: Zip Plus drive (OK)
Bottom: Parallel Port (NOT OK)
The connectors labeled 'zip' and 'AutoDetect" are the side that plug into the Mac.
ZIP drives are totally awesome and I highly recommend them. If you boot the system with the disk in the drive you don't even need a driver. The disk has a driver on it and it will load itself like it is a common SCSI Hard Disk.
