Yellow Be gone!
uniserver
http://www.amazon.com/gp/product/B00C7W5L44?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
off brand #40 developer by the gallon :)
techknight
Problem is, its gel based. Gel based stuff you have to keep babying it and it can cause streaking. I like liquid stuffs.
uniserver
i still have some machines that mcdermd retro brighted,  they are about 3 years old now and their still nice and white.
Juror22
Nice find, I'm picking up a couple.
From what I hear the yellowing comes back in a year or so.
I have not seen any re-yellowing on the ones that I have - some go back over four years.  I would assume that the different conditions that contribute to the initial yellowing, would contribute to any re-yellowing.  Probably Heat and Light.
Unknown_K
I never tried it myself, a good cleaning is all I do. Was reading about people over at VCF having the yellow come back over time. I would assume it depends on why the plastic yellowed in the first place and how bad it was.
CC_333
i think spraying the de yellowed plastics with some sort of UV protectant (something like ArmorAll, but not so shiny) can help slow down reoccurrance of yellowing.
c
Paralel
I've never heard anyone suggest a UV protectant product by name that will work.
On a similar note, I've heard that moisture has alot to do with how fast things re-yellow, in addition to heat and light. I've read of people that had stuff in cool closets that re-yellowed, and the only factor was higher than nominal ambient moisture levels. If this holds up, it would be a major problem for me, as I'm right near a large lake, and the ambient moisture in my place is 65-70% year round.
Apache Thunder
Cool. If I don't find something like that locally, that would certainly be where I get it now. :D
My Macintosh SE is only slightly yellowed. (and the fluorescent light in my bedroom makes it appear a bit more yellow then it really is) So I would think mine would likely not "re-yellow" after a few years.
I've turned the lights off and used my LED flashlight to try and get a view of it in more natural lighting conditions. (opening up the windows is out of the question. I will do my best to baby this machine. :p )
(even though it's almost 3pm, it still gets noticeably dark with the lights off. That's how well I got my windows blocked off. :p )
I have to look at the few nicks on the edges to see what the original color was (I had recently cleaned off some black markings and the plastic underneath was still original beige).
It's only gone a few light shades of yellow. So I would believe after retr0brighting it, it will remain beige as long as I take care of it. I have my bed room windows covered up with bedsheets (It's been like this for awhile as I have glare issues with my eyes) so the room is darker then normal. I would believe this also ends up helping protect my SE from unwanted UV exposure as well. :D
I live in Texas (Northern Texas, not southern Texas), so I don't think it's known for being very humid at all and the central AC of my house would also help keep humidity down. :D
My room does get a bit warmer then the rest of the house though. On average it gets about 80'F at peak summer heat if I keep the ceiling fan going. The rest of my family considers my room too hot, but I'm a bit cold natured. The temperatur swings in my room get a bit more extreme during the winter though. But I don't think it's something that will be harmful to my Macintosh in the long run.
In a month or two I may consider getting that. I may wait until I have an SE/30 before dropping $20+ on peroxide solution. I also don't have a clear bin to place the stuff in so it won't be cheap for me to do this currently.
The keyboard I am using with my SE is a bit more yellowed. I don't have a mouse yet. What condition my eventual SE/30 will be in will determine how soon I will attempt to get the stuff for this. :D
uniserver
From what i understand this Developer #40 creme solution is a bit different then the Retirbright method.
basically with this method all you need is this product , a paint brush, and the sun, for a couple hours.
then rinse and Yellow be gone.
one of my old buddys Jason,,, (aftermac)
he has an Obscene Vintage Mac collection.   Him and his wife caught wind of this simplistic method, (Developer #40) and
have been going through his computers one by one with, from what I understand to be 100% success.
http://www.macobserver.com/tmo/article/tmo_workspaces_jason
techknight
Oh you gotta keep on it with the paint brush while its in the sun etc etc?  so like every 30 minutes ?
they got the same stuff that is liquid, its like 2 bucks more.
http://www.amazon.com/Stabilized-Crystal-Liquid-Peroxide-HC-50409/dp/B00TP1IZDE/ref=pd_sbs_194_5?ie=UTF8&refRID=1WFY548HJGN6YJGQCPKQ
http://ecx.images-amazon.com/images/I/51YTyCv31rL._SL1000_.jpg
I am one of those "set and forget" type of people. Lazy.
Dunk it in the tank, let it roast in the sun and forget about it. lol.
Paralel
Isn't the problem with the dunk method that you lose the spray anti-RF coating on the inside of the compacts?
olePigeon
I've treated several buckets, and I haven't had any problems with the RF coating coming off.  I've treated both the thinner, shiner anti-RF, and the older, thicker dark gray stuff.  Neither came off.
uniserver
well the developer came in...  it was raining today. maybe tomorrow it will be sunny?   love Michigan in the fall :)
