I'm looking for a driver (System 9?) for a Yamaha CDRW 8424 external SCSI burner. Yamaha no longer has anything on their site and a Google search only finds Windows drivers. Anyone have any leads for such a driver?
The one that comes with Toast works great. If you can find a copy, install it on your machine and presto! Your drive will work just fine. I've got one of these Yamaha drives, too, and it'll only work properly either under OS X or with Toast installed on 8.5-9.2. Other CD authoring programs may work, and you may be able to find some non-Apple CD drivers, but Yamaha never released any drivers for Classic (at least not for their SCSI drives), according to the manual included with the drive.
Thanks for the info. There was a copy of Toast on the machine, so I moved two extensions into the extension folder, restarted, and Aha! the CD appeared on the desktop. Haven't tried burning yet but at least I can read CD's on that drive.
