LCGuy
LC Doctor/Hot Rodder
I have an AppleVision 1710AV display. As I mentioned about a year ago, it has a problem where the horizontal width goes out on it, and you have to literally belt the crap out of the display to get the image right again, for a few minutes before it goes again. I normally use it on a LC630 that has a Performa 5260 logic board in it, which can do 640x480 in 16 bit colour, or 800x600 or 832x624 in 8 bit colour. Today I decided to connect it to my LC475, and set the resolution to 1152x870. At 1152x870, or 1024x768, the display works perfectly, the horizontal width holds, the image is stable, and basically its like a new monitor. However, if I set it to any resolution below, it does all stupid on me. How is it that it only does this on the lower resolutions, and is there any way to fix it?
