Whats happened to my iBook G4?
Byrd
GPU/voltage regulator failure - press firmly down on the hand rest (you'll need to experiment) to see if you can get it to give more life.
jholt5638
I have a parts 12in g4 1.2GHz iBook if it is the GPU/VRM it works just missing the HDD. If you want it make me a offer
techknight
that is definitely a GPU fault. Seen it 1000 times. Strange one, but ive seen it. More common is all out corruption.
ive seen GPUs fail in odd ways. one of them being frozen picture and LCD fade to white with backlight still on.
SuperToaster
What I don't get is that when booting into target disk mode, start up manager, and open firmware the colors work fine. But just not in the installer for some reason. Guess I traded a nice computer for a broken machine :( I guess I could see if I could bake the motherboard, but I gotta figure out how to take apart one of these. I heard they are very difficult to disassemble. I have also gotten Kernel Panics when I was loading the installer from the CD It said it couldn't find the CPU driver for Powerbook6,7 maybe I just have to use a different OS. I will see.
IPalindromeI
Drivers probably trigger the GPU to do something other than display a framebuffer and into something that stressed it.
SuperToaster
Thats why I'm going to try to install 10.5. I tried installing 10.4 on a USB flash drive and it did the same thing as when I tried with the DVD
quinterro
I booted a Lubuntu 14.04 DVD and it looked a lot like the initial image.  The menu bar and the icons on the desktop looked okay but the background was gibberish.
