While there were Nubus DSP cards made for audio - notably the Digidesign Audiomedia series - and audio apps that used the AV Quadra's motherboard DSP, I'm unaware of any audio apps or drivers that were able to use the far more common (and in some instances, far more powerful) Nubus cards made for visual DSP work - the Photoshop and QuickDraw accelerators and the like. If you know of any, I would be very keen to hear of them.Some audio apps use the DSP.
Now that would awesome!SETI Work unit
So adding DSP cards (as long as they use the same type of chip) to a 840AV will add a speed boost? So the apps that are 'DSP aware' are Photoshop (see question below) and Picture Press. Does anyone know of others? I always wondered if anything actually used the DSPs in the 68K AV Macs.I think the Storm dsp card that was later absorbed into/by Radius used the same dsp chips as are found in the 840av, and as the system software was multi-processor aware in the case of the AV Quadras, such a machine could simultaneously use all the dsp cards you can pop in.
Hmm. I know that Apple made a QuickDraw accelerator that was a PCI card with no outputs. Was that what that card was?Some of the very early quickdraw video accelerator add-on cards were just a Nubus card with 2 DSP chips on them (sometimes with RAM cache).
It was? Are you suggesting that any app which can access the onboard AV-Quadra's DSP can transparently access DSPs on a Nubus card?the system software was multi-processor aware in the case of the AV Quadras
For audio work?such a machine could simultaneously use all the dsp cards you can pop in.
It can use the 56001 on the AudioMedia/AMII card for real-time effects on output, and compression/limiting/EQ on input while recording. It may be able to use other Digidesign/ProTools DSP cards, but I don't recall.Don't recall if DECK II uses just built in DSP chips or ones on add-on cards.
With the correct software installed they will speed up Photoshop, specifically in opening, saving, changing the file format and compressing files within photoshop. Back in the day these were being made and used, Photoshop was horribly slow when manipulating, opening and saving large high resolution images. I think a lot of people forget just how slow the processors were and just how horribly expensive even moderate amounts of RAM was - and Photoshop gobbles RAM like there's no tomorrow.What can be done with a NUBUS DSP card besides speeding up Photoshop? Anything? I've heard that they will speed up JPEG operations.
Erm, what else do you want to do with a DSP card designed specifically to speed up Photoshop?Are there any other operations they can be utilized in?
Well, I was hoping that there were more uses for the card. After all, those DSP chips weren't designed for Photoshop, companies just wrote the code to make Photoshop filters use them. I was also hoping there were more uses for the chips in the AV Macs. I do realize that with any specialty hardware that unless the code is compiled for the chips then they simply aren't going to work.Erm, what else do you want to do with a DSP card designed specifically to speed up Photoshop?
Yes and there's the rub.companies just wrote the code to make Photoshop filters use them.
There is a substantial amount of information in the "The Macintosh Quadra 840AV and Macintosh Centris 660AV Computers" Hardware Developer Note: http://developer.apple.com/legacy/mac/library/#documentation/Hardware/hardware2.html. Pages 231 to 289 or about 68 pages of information titled "DSP Operating System".Well, I was hoping that there were more uses for the card. After all, those DSP chips weren't designed for Photoshop, companies just wrote the code to make Photoshop filters use them. I was also hoping there were more uses for the chips in the AV Macs. I do realize that with any specialty hardware that unless the code is compiled for the chips then they simply aren't going to work.
and"... the architecture supports the implementation of NuBus cards to make configurations of multiple DSPs possible." (p. 61)
Putting two and two together, a multiprocessing machine for sound work would appear to be possible."A sound driver provides the interface between the Macintosh Sound Manager and the Real Time Manager by means of a set of standard sound modules, including sound input and output, compression, filtering, sample rate conversion, and mixing." (p. 66)
"The purpose of the various toolbox drivers is to provide access to the capability of the DSP at the highest possible toolbox level. This allows applications that are not written for the DSP to use it automatically when it is available. Even with this level of toolbox support, it is clear that many applications will work better by directly accessing the DSP using the DSP API. Such applications provide significantly more functionality or speed when a DSP is available. However, an application that uses the DSP API either cannot run on a platform without the DSP, or must provide alternative main processor programming if a DSP is not available."
