Using Magneto Optical drives on vintage 68k Macs
MrFahrenheit
Ah, I know very little about dye sublimation printers, but your labels look fantastic. Do you get premade floppy labels or cut them to size by hand or with a paper cutting machine?
MrFahrenheit
Those look really nice!!
Thank you!
@JAG The advantage of a dye sublimation printer is that it uses solid wax blocks in the printing process. It melts each of the four colors, and applies that hot wax to the paper. This creates a very uniform image, vs printing with inkjet or laser (which tend to be a bit streaky or be dependent upon the quality of the paper and its ability to soak up ink).
Dye sublimation prints onto the surface of the paper, and binds with the paper, giving it that raised feeling, almost like how business cards used to be made (where you could feel the letters with your fingers).
