Using ".Image" files to create floppy disks
khannonnd
This is probably a very simple question (and something I probably knew how to do way back when), but I can't seem to remember:
I am trying to create a bootable/installable set of OS 7.1 floppies.  I have .Image files of the set (Install, Install 2, Fonts, Disk Tools, Printing, Tidbits), and I want to create a set of actual hard copy floppies in case I ever need to reinstall 7.1 on my Powerbook 180.
I have a Wallstreet that has a floppy drive, so my plan was to burn a CD with the .Image files and then use that CD to move them over to the Wallstreet.  Once the .Image files are on the Wallstreet (which is running 9.2), what do I use/do to write these images to the floppies?
BadGoldEagle
From your Wallstreet, you just need to fire up Disk Copy 6, mount the .image files and drag the "media" (aka mounted image) to a blank 1.44meg floppy disk. Click OK. Done.
rsolberg
The Wallstreet is a rather handy machine as a bridge. I have a 2GB CF card formatted HFS+ that I drop files onto via a USB card reader on a modern Mac. I used HFS+/Mac OS Extended (not journaled) to preserve resource forks, but unlike HFS/standard, I can write to it in El Capitan natively. I then slip that card into a PC Card adapter and stick it in the Wallstreet. Mac OS 8.6 mounts it on the desktop and I can make 800KB or 1.4MB floppies from its contents to my heart's delight.
khannonnd
Which CF reader do you use on the Wallstreer? That's a great idea and would save me from having to burn CDs.
rsolberg
I have a handful of them. There's a Lexar and a bunch of no name brand ones. They're all 16-bit and passive adapters, so they're super cheap and don't require drivers at least as far back as Mac OS 8.1 and Windows 95. I did an eBay search for "PC Card compact flash" and there are loads of them for under $3. They're still popular because many older high end sewing/embroidery machines have a PC Card slot for storage and adding designs.
khannonnd
Thanks for the great idea;  I'll pick one up!
