3lectr1cPPC
Today I wiped my eMac clean and dual-booted Mac OS 9 and Sorbet Leopard on it. It’s a 1.0GHz model, but it’s the SuperDrive variant that doesn’t officially support OS 9 booting. The macos9lives patched CD took care of that pretty quick, but because it’s unsupported, the OS 9 partition doesn’t show up in the OS X Startup Disk preference pane. I can select the OS 9 drive from the bootpicker, but this takes a lot longer due to having to wait for it to finish searching the bus for bootable volumes. Is there any way to force the OS X preference pane to show the OS 9 volume, or am I stuck doing it this way? OS 9‘s control panel has no issue selecting the OS X volume.
Thanks!
Thanks!
