ktkm
Hello!
Just bought a ”TwinSpark” cache Adapter from Stratos Technology, to my Daystar Universal Powercache 33 MHz (MC68030FE33B), for use in an SE/30 (of course).
After installation I’m able to boot up once (with Power Central installed), with system 7.1 running Apple diagnostics and Power Demo (without problem), then after 10 minutes the system freezes. After reboot the sequence freezes again when loading Power Central. I’ve been able to get the same result with two different logic borads!
Is this a typical incompatible problem between the TwinSpark adapter and older versions of the Universal Powercache? Or is it a problem solved by moving some of the jumpers on the adapter?
Sincerely,
KTKM
Sincerely,
KTKM
