Twin PCI Riser Project for TAM, 6360, 5x00 Single Slot PowerMacs.
Trash80toHP_Mini
NIGHT STALKER
Silly question: has anyone ever removed the backplane plate and RJ-45 connector to fit a CSII NIC directly into mobo slot? Looks like there might just be room enough to do that. You can trim quite a bit off that end of the board too. Lop it off right up to the thruholes for the RJ. The only component lost would be the LED and that could be wired from the vias to wherever. That's a full centimeter removed from face of backplane plate to just shy of the RJ thruholes. That way you could use CSII (low power draw spec) and a combo of fairly low power draw PCI cards at the same time. Maybe a USB card and a "just good enough" video card. [}:)]
Trash80toHP_Mini
NIGHT STALKER
Nobody has posted a pic of the inner surface of the Fat Back, One would be much appreciated because I'm concerned there might be reinforcement ribs molded into the surface which might physically conflict with the second PCI card. Also requested would be pics of the Backplane/Fatback combo from a few angles so I can judge how much clearance there is from the joint between the two.
A simple yes or no answer as to whether the inside of the back is a smooth surface, will work for now.
Since I'm in reorg/downsize mode, it was easy to find at least some of my printouts and notes from this project so I can futz with it during downtime at work. I can peek and poke at the FauxBenchTAM I've yet to button up for storage without much impact on reorg time at home.
EvilCapitalist
I'm pretty sure it's just smooth inside the fat back.  I don't think there are guide tracks or anything like that in there but I can take a picture later this afternoon.
Trash80toHP_Mini
NIGHT STALKER
Excellent!, thanks so much. Given some downtime tonight, I can fiddle around with making cardboard prototypes for testing the fit in TAM, 6360 and their AIO kin. I've got a pair of connectors, contacts pulled and ready to drill and tap so they can be bolted up to any of the four cardboard mockups. If the 2cm offset board is too tall to fit you can test the tighter spaced, lower profile version. After the 6360 trials I can get the TAM boards out to you. I'll also trim a modem PCB for test fitting a bobbed NIC installed directly in the CS2 slot. Doubtful, but given enough clearance for components it may just fit into the skinny back?
EvilCapitalist
Sure, I can test whatever you cook up.
The skinny back is so skinny that certain RAM sticks won't fit in the machine with it installed, so I don't think you'd get any usable clearance to be able to have anything in the PCI or CSII slots.
Trash80toHP_Mini
NIGHT STALKER
Well, then you might be able use the Bobbed NIC in the CS2 slot and two PCI cards so long as there's no accelerator to soak up the Power.
Trash80toHP_Mini
NIGHT STALKER
It fits!  [:D]   Twin Slotted 6360 with Video Card in standard position and one of my precious Sonnet TEMPOtrios in the upper, setback slot from a few angles.
Cardboard "PCB" Riser, had to go with the lower position, but I may be able to raise it half way back up?
I've got room to set the card about half an inch farther back into the drawer, that will make it easier to break USB and FireWire out the vestigial LC PDS slot port.
Overview of the entire drawer, chock full of goodies, AV card and CSII NIC are missing. The redundant TV Tuner needs to go to make way for a squirrel cage fan or the like.
In this configuration I was surprised that the cover plate on the upper card is only about 1mm shy of clearing the top of the opening. I've got room to raise the top card a bit closer to standard slot spacing. Only a low profile card will work in the top slot for the real deal. I think there may be even less cubic in the 6360/5xxx drawer than is available in the TAM's Fat Back
Gotta figure out where to put the SSD and how to snake the cable from the TRIO's ATA/133 connector to it.
Too bad the TRIO isn't compatible with the TAM or my 6500 boards  .  .  .  oh well.
Next up: TAM testing!
Trash80toHP_Mini
NIGHT STALKER
I think I've got it: low profile bi-directional PATA<->SATA adapter.
I can desolder the PATA cable connector and install a socket on the flip side to plug directly into the ATA/133 cable connector of the TRIO. Desolder the MOLEX connector and wire up a 5V connection for the Adapter alone. That will drop the SATA connector underneath the TRIO PCB for snaking only a SATA data cable to a SATA SSD powered from another source. That way I only have a ropelike SATA data cable to deal with, no ribbon cables involved at all! :grin:
That's it for tonight  .  .  .  zzzzzzzzzzzzzzzzzzzzzzzzzzz :scrambled:
Trash80toHP_Mini
NIGHT STALKER
TAM - It should fit! [:)]
Some nasty surgery on the USB cable connector I lopped off the other day. An adapter PCB would be my first choice, but a hacked cable snaked out the back through a printed strain relief CSII port cover might be ideal, Ya gotta have a cable, may as well make it a fixed feature?
Tested in a worst case scenario: the TAM Backplane template is set so the slot cover is at least 1.25mm lower than it should be IRL. Everything fits within my estimated profile of the arc of the side/backplane. The center of the standoff's top surface aligns with the arc, leaving a a couple of millimeters clearance for the ATA connector edges on the TRIO. The curvature of the Fat Back's inner surface gives even a skootch more clearance. Trio itself it a near worst case configuration.
I don't have a card with FireWire connectors mounted upright above USB connectors. That would be the absolute worst case, horizontal connectors are 19mm wide 19mm wide and the standoff/estimated edge of the arc is only 16mm so it all depends:
-  how high theFW connectors might be mounted on the card
-  how much the second slot can be backed off to harvest more clearance from the curvature of the Fat Back
-  how much headspace the joint between side/backplane plate and inner surface of the Fat Back might offer
Dunno, USB only cards for the TAM/6500 are a lot(?) easier to come by than compatible combo cards. I need a figure on how far back I can move the upper slot in the TAM.
Comments?
Paralel
You made a foam board with the actual connectors first, to figure out the 3D interplay of all the parts? Genius!
I think I will have to steal this idea for a card I am contemplating making, based on a suggestion you made regarding the blackbird recently.
Trash80toHP_Mini
NIGHT STALKER
Thanks! I've been playing around with prototyping all kinds of stuff out of all kinds of stuff IRL since the Apple I came out. Not foam, it's two layers of what appears to be four ply glossy one side card stock about .4mm thick.  The six ply I've still got on hand from over fifteen years ago is about .5mm thick. With rubber cement between the card stock halves and holding the laser printout paper on their outer surfaces I wind up with about 1.25mm overall thickness which fits into an edgecard slot snugly, but not tight as real FRP stock/edgecard connector which is on the order of 1.6mm in thickness according to my digipers.
I think poster board from a drugstore is four ply, dunno, I get all I want for free. I do the pasteup on the matte side, score and fold along the top edge so the printed sides are cemented together. A little work with a matte knife and it's an Instant laser printed, multiple ply laminated PCB protoboard you'd never know had been part of a big offset printed sign.
Funny you should mention your Blackbird procswap, I'll pop in for a couple of comments. Something you mentioned got me thinking about your project. [;)]
