Damian Ward
I'm having trouble with one of my SE/30's. The SE/30 is booting from its internal hard disk, it loads all the extensions and control panels. Then displays the message "Disk initialisation failed because the disk is locked". I can click OK to clear the message but it then comes up again, leaving me no option to continue.
I believe it may be something on the analog board, as I have swapped the hard disk and logic board for ones I know work, but it still comes up with the same problem. I have looked over the analog board for leaking capacitors, but everything looks good. Has anyone else had this problem?
I have posted a picture on Flickr, showing the message. http://farm2.static.flickr.com/1108/3267548042_375cf31bb6_b.jpg
