Scott Baret
My apologies for being away for a while...but I return with what may be the strangest LC problem ever recorded.
I got my LC out of storage on Saturday. All was well. I was using it without anything out of the ordinary until tonight.
The monitor, a 12" Apple RGB (the standard LC monitor) keeps flickering on and off, but only in one respect. Half of the blue pixels go out. The others are fine (all reds, all greens, and the other half of the blues). I tried unplugging the video cable and reconnecting it. No difference was made there. It has gotten progressively worse as far as how often this happens (it will come, stay for a while, then go away).
However, it DOES NOT DO THIS when I set it to "THOUSANDS OF COLORS". In fact I can go to the monitors control panel, select thousands, and it will fix the problem if it's present...and it returns if I set it back to any of the other four settings.
This is making me wonder if maybe I have a bad VRAM chip or something? (It's a 512K I pulled from an LC II five years ago). Or maybe there's a problem with the blue pin, although it looks perfectly fine and does fine when on thousands of colors mode.
I may try the monitor on another Mac tomorrow just to rule that out, but the monitor has no signs of anything wrong when it's on thousands of colors mode. Trouble is half the programs I have on the LC want either 16 or 256.
(The pattern of problem blue pixels, BTW, is pinstripes. It literally looks like a prison cell without those blue lines there. I am hoping it's not a capacitor issue.)
I am thinking it's not the blue pin though...put it on black and white mode and it's a white line pattern through the screen as in prison cell pattern with the bars further apart...this is proof that my blue pin is working fine.
I'm thinking VRAM off the top of my head?!?
