GrizzlyKiwi
I got given a dual 1.25ghz G4 MDD that has been through the wars and the case is all bent.. basically its stuffed but the insides might still be good. Is there a way I can power on the system on the bench without a power button? can I short some pins on the logic board like you can on a standard PC? The power supply is stuffed as well so I had planned to convert an atx one to do the testing.
