scroll1
I have an Apple IIe enhanced as well as a normal IIe.
The duper serial card works in the normal IIe, when I use ADTpro I type:
]IN#2 (in card slot 2)
] (ctrl -A)
and I get to the SSC: command prompt.
Everything works well.
However, if I place the same card into the enhanced IIe model and trying various slots, I cannot get into the SSC prompt.
Can anyone make a suggestion?
Thank you
] (ctrl -A)
Thank you
