super serial card
scroll1
I have an Apple IIe enhanced as well as a normal IIe.
The duper serial card works in the normal IIe, when I use ADTpro I type:
]IN#2 (in card slot 2)
] (ctrl -A)
and I get to the SSC: command prompt.
Everything works well.
However, if I place the same card into the enhanced IIe model and trying various slots, I cannot get into the SSC prompt.
Can anyone make a suggestion?
Thank you
luddite
Host of RetroChallenge
Does the enhanced IIe work normally otherwise? Have you tried any other expansion cards in it?
scroll1
The machine seems to be functioning correctly. The strange thing is, I can get the serial card to work booting from an ATDpro floppy and choosing serial. It then communicates with the XP box no problems. That floppy was made on a standard Apple IIe. So the card works in the slot, I just cannot get it into SCC mode by typing:
IN#2
(ctrl-A)
thanks for any help,
Wayne
scroll1
actually, I'm beginning to wonder if my "control" key is actually not working properly. It does beep when I press control-A but places a faded block cursor at the prompt and then a full coloured rectangle cursor blinking 2 lines above the last line....
Is there any test I can run on my keyboard?
ok, confirmed: my actual keyboard is at fault, I hooked up a standard IIe keyboard and ctrl-A gets me a SSC: prompt.
Now does anyone have a clue why that would be?
Dog Cow
Key switch is not so good on the control key, I think. I had the same problem with a //e I received a few weeks ago. The 'W' key would not work for almost 2 weeks, then suddenly it did work. Could be dust, grime, or other stickiness lurking below.
scroll1
Thanks for all your suggestions.
Now having tracked down the problem to the keyboard, I pulled it off and blew it out. The key is functioning correctly (testing with a multimeter), but There must be something else wrong on the keyboard circuit. I did "exercise" it for a while. But when it is plugged in I get a definite beep response from pressing the control key, I am not sure what it thinks has been pressed and whether that beep is an error.
I looked over the circuit board from the back and it is fairly clean except for some dark marks around the ribbon connector.
I suppose I am just on the hunt for a replacement keyboard.
