quinterro
I have a Beige G3/400 with 128MB RAM, a 9GB SCSI hard disk and a 3GB IDE hard disk. It also has a PC Compatibility card (Pentium 166) with 80MB RAM (16MB built-in + 64MB DIMM), a Voodoo2 and a USB 1.1 card.
The weirdness started when trying to make a hard disk image file. When I created one on the 9GB drive and tried to initialize the drive the Mac would freeze, requiring me to press the power button or pull the plug. When I made the image file on the IDE drive it worked just fine.
The strangeness continues when trying to format the drive under DR-DOS. When trying to format the drive, the PC locks at 2% of completion. If you do a quick format it locks at about 83%. Using FDISK to wipe the drive and verify its contents locks at sector 5000 of 63000.
I'm beginning to think it is caused by DR-DOS. I'll try with MS-DOS to see if it gets any farther along.
Any ideas as to why it is behaving so strangely?
