Oh, I am sure that's exactly what it is, but the G3 Mini tower has a sled/cradle whatever you want to call it that doesn't have any way for me to secure the adapter to it. I am not putting it into a spare slot, I'm putting where the original was. It's okay, though. We are a metal fabricating business here, and since they're eager to get this old G3 running off of an SSD, they made something for me.Are you sure that the plate it was mounted to isn't a 2.5" to 3.5" adapter?
Thanks, I ended up using a custom made piece. There are perks to working for a metal fabricator.This should work okay: https://www.amazon.com/dp/B016498CK0/ It has screws on the bottom, which some 2.5 to 3.5 adapters tend not to.
I tried Macintosh 12" RGB monitor, known to work, on the built in video. Nada. I tried a Dell Flat screen with a VGA style plug on the ATI card. The ATI card has ONLY a VGA type connector on it, no Apple. Nada. I can grab another monitor, I have several spares.Check your display device (monitor, LCD panel) and cable and any adapter.
Wouldn't know how to answer this, so I took a picture.Now if the video card was originally a PC card and was hacked with one of the "reduced" firmware packages to work on a Mac, then it might need drivers.
As long as I have been playing with Macs, you think I would remember to zap the PRAM. Thanks. That's next.Also, it is possible that the video card is in some weird state/configuration where it's trying to drive the display at an unsupported resolution. You may wish to zap the PRAM (hold down cmd-opt-p-r simultaneously) at power up/reboot.
Again, don't know how to answer that. So I took another pic. Also, thanks for the link. That could be useful in the future!Finally, but maybe this should be first, if you have a VRAM module installed on the motherboard, check that it's installed properly, hasn't popped loose. Perhaps clean the contacts.
Now that's the first tim THAT has ever happened. I double checked to make sure I had the right keys pressed down, but I am only hearing the startup chime once. I am not getting a second chime. I switched out the PRAM battery. I switched keyboards. G3 will start up, I get one chime, no more. Something is definitely wrong here.As long as I have been playing with Macs, you think I would remember to zap the PRAM. Thanks. That's next.
It took a while to find it, but the ATI Rage card is definitely the Mac version. http://macos9lives.com/smforum/index.php?topic=4257.0 is a lookup of ATI Card part numbers, and mine was on it. I am still getting no video out of the G3. I tried zapping the PRAM (which will not chime more than once), resetting the NVRAM and resetting via the CUDA switch. I looked up VRAM modules, I don't see anything that looks like that. What I have in my PCI slots are as follows an audio card with telephone jack, a Firewire card, and the ATI Rage 128. I have attached pictures front & back of the Rage card. There is some yellow residue on the 2 foil squares on the board, but aside from that, everything is looking pretty good. There is definitely something wrong here, and it's beyond my skill set to figure what it is. I have a couple more beige G3s. I am going to haul out another and see if I can get it to work.The ATI video card, if it is a Macintosh version, should produce video without any drivers. Drivers enable acceleration and sometimes additional resolutions, but any video card with Mac firmware should produce images at boot time, without loading disk based drivers. Hence, I suspect your display device, rather than the video card.
Not moot any more. Dang thing is acting up AGAIN. I haven't been using the Apple monitor, I've been using a Dell flat screen. I pulled out the sound/modem card and the VRAM would go into that small whitish frame, wouldn't it? Nope, nothing there.Moot now, but if you have a VRAM module (may be called GRAM in Beige G3) it would be under the modem that is sticking sideways out of your sound card. Behind the voltage regulator and between the RAM and sound/personality card.
Also moot, but another thought I had was perhaps the 12" monitor doesn't do 640 X 480? I think there was a small Apple monitor that was fixed at something lower like 512 X ?
Are you actually in Warren Ohio?Any recommendations for a good place to buy replacement IDE/ATA ribbon cables? It's going to be not fun to thread them through the case like you have to on the minitowers, but if I can pick up a couple for cheaps, it would be worth it to see if that fixes what isn't working. Would love a line on a new PSU or two as well.
The 12-inch color monitor does 512x384, and the 12-inch grayscale display does 640x480. I'm around 90% sure system 9 will recognize and work with both on built-in mac video.Also moot, but another thought I had was perhaps the 12" monitor doesn't do 640 X 480? I think there was a small Apple monitor that was fixed at something lower like 512 X ?
