Sure is. It's great to know there's someone else nearby who still uses older Macs!Because I am in Youngstown, odd seeing somebody that close here.
I have no idea how to modify cables. Know any good tutorials?You might have to modify the new cable too since the mac doesn't have the key pin removed from the IDE pin header on the motherboard.
I am going with the SCSI2SD. It actually was a piece of cake putting it in and firing it up. My video and PRAM zapping problems all appear to be related to either that CD-ROM or its ribbon cable, because my issues start whenever it is plugged in. It doesn't matter which IDE port. The PATA hard drive I have works just fine off of wither port, although it's kind of slow and pretty full. I bought a 512 GB SD card. That should give him some space.Did you end up using the OWC SSD or on a SCSI2SD?
Hi Cory. The SCSI2SD isn't all that expensive any more. It cost about the same as a 120 GB SSD. The SD card was the more expensive part, because I wanted a honking big one. The v 5.1 SCSI2SD has software termination built in. It was ridiculously easy to configure it for the G3. I haven't et installed OS software onto it yet, I still need to figure a way around the malfunctioning CD-ROM to do that.For the SCSI2SD - this sounds a lot like my issues. Are you using a SCSI cable with termination? any external devices? Is termination enabled or disabled as appropriate in the device settings?
I isolated the problem with the CD-Rom before I installed the SCSI2SD. The CD-rom isn't SCSI, so I am confused as to how termination settings on my SCSI bus could be causing problems?I guess my question is:
If you take out the SCSI2SD, does the CD drive start working again?
Yes, the zip drive is SCSI, and it is working properly. I do have 2 non-working desktop G3 machines. I will swipe the CD-rom out of one of them to see if it works. I also have a G4 and another SCSI2SD board and another 512Gb SD card. I could put it into the G4 (which does have SCSI) and write everything I need onto the SD card that way, then simply switch SD cards in the G3.I did something, the machine didn't like it, and when the machine was in that config, the CD-ROM and Zip drives didn't work. I undid whatever it was and they both started working again.
Maybe not so strange really, given the many odd configurations available. These are the clearest set I could find on EveryMac:Which, again, yeah, I know, weird because the CD-ROM drive is IDE and if I remember correctly the stock Zip drives (mine's a /300) are SCSI.
