beachycove
My Color Classic, converted to a CCII, has had since purchase a rather loud 80mm case fan. The noise is caused by the sheer quantity of air in circulation, and the sheer number of obstacles presented to that airflow in the Color Classic. It was not a case of a squeaky fan needing oiled.
I was on the lookout for a slower fan, or for a rheostat or the like to adjust the fan speed, but could not find anything locally and did not want to go to the trouble of buying on eBay and waiting for it to come. So, on an experimental basis, and during our recent little 68kmla-less interlude, I installed a 1v, 100 Ohm resistor on the positive line of the fan, in order to slow it down.
This worked fine, and I find that the noise is now greatly diminished. The air venting out the back is less than what was venting before, and while enough to be audible still in moving past the vent grating, is certainly no longer irritating.
The vented air, however, is slightly warm once the machine has warmed up (after 30 mins. or so of use). The heat is evidently being generated by the CRT, as when the screen enters sleep mode, the vented air will be cool. The computer's casing remains cool always, as does the physical screen itself.
Advice sought on whether or not to keep it this way, to replace the resistor with another — either with a higher voltage rating (cooler?) or with a lower resistance so as to allow the fan to spin faster — or else to return the machine to its former noisy self and play it safe.
