SillyTinySCSI - Smallest SCSI emulator! (ZuluSCSI OSHW)
zigzagjoe
The TinySCSI has a brother now: The SlimSCSI
Where the Tiny SCSI prioritized flush fitting, ideally for compact macs, SlimSCSI is the more compatible relative that should easily fit on anything as it is the thickness of the DB25 connector only. Push-push type microSD slot and microUSB facing away from the DB25. Functionally 100% identical to the Tiny.
These are fairly straightforward to assemble, so I may offer them in kit form as my PCB assembly capacity is 100% booked with accelerators for the moment. Assembly is solder the pico, solder the DB25, and solder jumper wire from the pico to the board for USB. Any interest?
