Byrd
Hi,
I picked up an "as is" Powerbook 1400cs/166 from eBay for ~ $25 BIN, untested. It arrived tonight with the specs of stock 16MB RAM/1.3GB HD, floppy drive, and Newertech ethernet adapter in the proprietary "upgrade" slot. Not in bad condition bar some cracking around a screen hinge. If I get it working I'll try to find some RAM for it and get a 'c' TFT panel from powerbookguy (assuming shipping costs are reasonable).
Once plugged in, it fires up immediately, boots to Happy Mac then "bus error". Pulled out the hard disk and can now get it to boot to desktop from CD; seems the HD is definately gone.
I've a spare 10GB HD I'd like to install, but the hard disk ribbon cable seems stuck, it won't slide out from the plastic trim it slides into. The service manual suggests it just slides out a few cm. Any tips on how to slip it out?
Thanks
JB
Thanks
JB
