mx-v
Ok, now I'm officially stumped.
I have a PowerMac 7300 (Mac OS 8.6) networked with a PowerBook 165 (System 7.1) via PhoneNet. The IW II is connected to the PowerBook. I want to print on it from the PowerMac.
Should be easy I thought. Well, it's not.
File sharing works. LocalTalk using serial ports, IW II hooked to modem port.
Everywhere I looked referenced a "Setup" button in the chooser which is just not there, regardless of what version of File sharing or ImageWriter extensions I use.
What am I missing here?
