SetDate CDEV and Clones = shenanigans
Crutch
In other news, I just successfully got my version of SetDate to crash with a bus error! I failed to correctly dig in though and now can’t replicate it ...
jessenator
Okay, one more stupid thing I tried… that seems to have worked in 7.5.3:
  1. Zapped the PRAM several times (my clock was still set… weird)
  2. I disabled MacsBug
  3. Set the clock to 24 hr in Date & Time panel
  4. I saw an option in the Memory panel "Modern Memory Manager" and turned it to off (I'd forgotten that existed… thought, 'why not?')
  5. Rebooted, opened SetDate: set the time first, no crash. Set the date???!?!?!?! NO CRASH.
Well, on the StarMax 5000/225 I got SetDate to work (under 7.5.3) by simply doing steps 2–4—no disabled extensions (I did disable MacsBug…). It also appears the preferences on the clock within Date & Time, generally, were saved having moved the startup disk from Mac to Mac: so 24-hr, show century… Not going to jinx it by switching back to a 12 hr clock…
Not sure about a workaround in 7.6.1 though… I don't recall if the Memory panel has that option to disable it or not.
jessenator
Installed 7.6 (as an upgrade) and 7.6.1 update over the original 7.5.3 install and all seems working. Also, strangely, it somehow set my clock to a 12-hr, yet still retaining the correct date.
So I got that going for me, which is nice. I don't know what will happen when it comes time for a new battery :/  Maybe I'll have lost my love for 7.x  :tongue:
jessenator
I'll update this with the post that was lost.
As an alternative to SetDate, there's a 2020 Patch: a simple system extension that allows you to set the date with the Date & Time control panel!
Works with every Mac and clone I have. No troubles.
