Buickguy
I've got an old SE FDHD with a problem. I had set it up for my 10 yr old nephew with system 6.0.8 and a copy of MOTU Performer 2.2 to get him started with keyboards and midi. It was running well untill Saturday when I fired it up to add some sequencesfor him. The HD seemd to stop responding so I restarted and got the Startup floppy qiestion mark. Starting up on a system floppy with HD steup revealed no scsi device available. My first thought was drive stiction failure but further investigation showed the the drive was spinning. I opened it up and found the pram battery (battery dated 10-89) had leaked and capacitor CR 33uF 16v had become detached from the motherboard. :-/
In the meantime, I'm hooking up the nephew with a Q605 chipped up to 33mhz and the 25mhz LC040 swapped out with a 33mhz full 040 and secondary CPU heatsink/cooling fan.
So my question is this, Has anyone had any experience/luck with replacing this cap and will it's replacement solve the issue? I do have an Se with 800k floppy and 20 meg HD in reserve so would I be better off changing the roms and swm then using that motherboard? I'm fairly comfortable with the soldering pencil and all even though its been a few years.
