SE fdhd in need of screen adjustment
marcelv
Hi,
I have a problem with a SE fdhd, the system is working ok, except for the screen. The top left corner seems to be lower than the right one. The overal picture is reasonably straight.
In the second picture i have drawn a box around the screen so you can see the problem better.
Can anyone tell me how to adjust the left top corner?
SlateBlue
I believe the magnets attached around the yoke are used to adjust the corners/edges. If you look at the yoke from the rear of the Mac, you'll probably need to adjust the one at 1 'o clock. All it takes is a gentle twist one way or the other. Look at the screen as you twist to find out which way. Then you can use a dab of paint or hot glue to hold the magnet in place.
Themk
A little adjustment goes a long way with the magnets, and once they are freed, can easily be shifted, so you will want to put something in there to stop them from moving later.
