SE fan replacements
bbraun
I've got an SE with a really noisy fan I'd like to replace. Unfortunately, the SE uses an odd paddlewheel style fan instead of the fans you typically find in systems since that time. Does anyone know an equivalent part, a conversion to a modern fan system, or another solution?
bbraun
get a metric ruler, go from there, its one of 3-5 sizes
It is approx. 70mm tall with a power lead running nearly the length of the analog board. From your post it seems as though this is a standard fan type which is readily available, although I am not familiar with distributors of suitable replacement fans. Could you enlighten me?
Here are some pictures:
Bunsen
Admin-Witchfinder-General
That's called a squirrel cage fan. It's more common in industrial and automotive applications, and, as you have surmised, is not a common or readily available computer part.
It may be best to see if you can find somewhere to mount a standard computer fan and find one to suit.
Mac128
Larry Pina has a very clear procedure for doing this in his book Mac Classic & SE Repair and Upgrade Secrets. It was a very common upgrade at the time. Books can be found readily and inexpensively on Amazon.com and other used book sites.
bbraun
Thanks! I'll grab a copy and take a look.
