If you've got an SE there's about a 50/50 chance of having one or the other from my observations. The Samsungs are rare in Classics and Pluses/pre-Pluses. As I mentioned in my stickied CRT thread there is no functional difference between the two manufacturers although the Samsungs do have a different hue of white to them than their Clinton counterparts. You can only tell this difference if you place it next to a Clinton. If you compare geometry problems between the two there is no advantage to either side--most of these CRTs are actually pretty good in terms of geometry and don't distort themselves over time like Trinitrons tend to do (I've seen a lot of Hi-Res Apple monitors and Color Classics that need geometric adjustments, far more than I've seen the shadow mask 12" display or the compacts).
I recommend only swapping the CRT with a fully compatible "Type A" or "Type B" counterpart (my taxonomy is explained in the stickied thread). All SEs use "Type A" and the best bet is to pull one from an SE or other "Type A" CRT machine that is being parted out.
If you're diagnosing SEs and want to see if a CRT is good or not, make sure you are using a problem-free analog board. Screen jitters, noise, and low brightness are almost always caused by a bad analog board and not the CRT itself.
Also, the SE self-discharges its CRT when the power switch is turned off and the machine is unplugged from the wall. To be safe, though, I always use an insulated pair of pliers to remove the anode cap (the red suction cup-type connector on the left side of the CRT when looking at it from behind). This is the part that can electrocute you when the machine is turned on/plugged in. Some play it safe and discharge the CRT; I find that the self-discharging mechanism in the SE and Classic do not necessitate this procedure. Replacing the CRT is fairly straightforward; once you get a replacement let me know and I can walk you through it (let me know if you want me to send a video tutorial on how to do it, as I can record one during my SE parting-out sessions).
