Boctor
Since I bought it a few years ago, the analog board on my Macintosh SE SuperDrive has suffered an odd problem, where the picture often changes scale/brightness. It happens occasionally when the machine is running normally. The picture becomes brighter, slightly wider, and about 1/3 of the screen (on the left) becomes slightly dim. I believe it also gets a bit squashed, vertically.
If the analog board is moved or tapped even slightly, the screen changes between normal appearance and the messed-up state. The board does not need to be warped or stressed in any way for it to occur. I finally recorded the issue, and I'd be grateful for any expert help on what part of the analog board is causing this. None of the components appear to be loose; I cannot find cracked joints anywhere.
An example can be seen here. I hope the diagonal scanning recorded by the camera is not too much of an issue.
