SE/30 Video Section Replacement Parts
superjer2000
Does anyone have a list of known good Mouser or Digikey part numbers for the following SE/30 ICs:
UE8 LS166
UF8 and UG8 LS393
UA8, UB8 and UC8 74F253
Thanks!
superjer2000
UE8 LS166
UF8 and UG8 LS393
Thanks!
I can confirm the following:
UE8 LS166: Mouser Part # 595-SN74LS166AD
UA8, UB8 and UC8 74F253: Mouser Part # 595-SN74F253DR
I haven't yet needed to replace a UF8 or UG8 but I ordered and am pretty confident that 595-SN74LS393D will work.
Bolle
I had to replace UG8 once. Replaced it with a LS393 from mouser - worked just like new afterwards. Probably was the same you found as well.
ThisDoesNotCompute
I didnt realize it but UF8 and UG8 are 14 pin chips but the rest are 16 pin chips.
Are we certain that A-E are the same?
Sorry, I should have said UA8 through UD8 are the same.
Here's a BOM of all the parts on the SE/30. What you're looking for is on the "Top-Side PnP BOM" tab. Any chips that aren't available as commodity parts are on the "Top-Side Special Parts" tab.
https://docs.google.com/spreadsheets/d/1Nx-KRaF5cdhcJSdrX42SqrtQcKcN2UZhHbEiThW19gc/edit?usp=sharing
smrieck511
