SE/30 to modern Mac via serial cable
megabyte
Hi all.
I try to connect SE/30 and iMac 2017 via serial connection using next components:
- mini DIN 8 to DB25 mac modem cable (bought on ebay)
- DB25-DB9 converter
- DB9-USB serial controller
At SE/30 side I tried to use ZTerm with different speeds (19.2-115.2).
At Mac side I tried a lot of serial terminal software (minicom, Serial, hyperterminal+virtualbox etc.)
Both computers has XON/XOFF handshaking turned on.
Both computers transmit characters without any problem. But when I tried to send file via ZMODEM I always has a CRC-error on SE/30 side. I tried to use all options of ZMODEM settings (window size, special characters filtering etc), but got no result.
It seems to me that transferring files through the terminal should not be so difficult. What am I doing wrong?
ironborn65
this is of interest to me as well, since I have a similar arrangement.
On the modern side I have a Bigsur an a MacBook Air Silicon, on the legacy a Mac Classic.
I can transmit characters using ZTerm/Classic across any terminal software on the modern Mac but sending files fails to me because I did not find any ZMODEM capable software on the modern mac, so the protocol is not implemented on one end.
So I tried to use BasiliskII in the Mac to take advantage ZTerm, but despite many attempts Basilisk does not see the virtual serial port.
I was inspired by this https://www.savagetaylor.com/2020/1...transfer-from-basilisk-ii-to-a-68k-macintosh/
I hope this might somehow help
Byte Knight
Hi all.
Try Zoc terminal program on the iMac side - it's the best modern terminal program out there: https://www.emtec.com/zoc/
You could also try YMODEM or XMODEM protocols .
4seasonphoto
This sounds really familiar, and I think your problem is maybe with the Mini DIN-8 -> DB25 cable. When higher speed modems became popular, a revised Mini DIN-8 - DB25 cable with support for hardware handshaking became necessary, but even in the 1990s, there were lots of the older-style cables still in circulation, and there's usually no way to tell what you've got without checking with a multimeter. You can often reuse the existing cable by cutting off the DB25 end and reconfiguring (assuming the DIN-8 side has all pins connected, which IME it usually does). Here's how a proper cable should be configured:
https://kb.iu.edu/d/achi
I seem to vaguely recall that unless this was done, you could send strings of characters between computers, but file transfers would fail, exactly as you describe.
4seasonphoto
shouldn't it be a null-modem/cross cable?
Yes, but if you can type characters from one machine to the other, then something is already acting as null modem adapter because if that weren't the case, you wouldn't be able to send even that across.
Also, IIRC standard ImageWriter II mini DIN-8 cables are already wired as null-modem.
gibbsjoh
I've followed the same instructions as OP and get a connection, but it's like the Mac is sending carriage returns over and over again (see video).
I've tried 1200/2400/9600, RTS/CTS, Xon/Xoff, Zterm and ConfigPPP, Modem or Printer port, everything yields the same result. PowerBook 145B, System 7.1. It's a Din8 to DB9 cable from Amazon and a generic PL2303 based serial to USB converter.
I also tried an x64 Linux box as well as a raspberry pi, same issue. I am manually telling the system to listen using agetty -F /dev/ttyUSB0 {speed}
I can start a new thread if needed... figured I'd try here first.
gibbsjoh
(Just realized today that I'm not using a null modem-wired cable, as far as I know. A null modem adapter arrives tomorrow so I will see if it makes a difference!)
Agree with @4seasonphoto here, @megabyte 's problem (not to refer to you in the third person rudely, just to differentiate problems!) smells like flow control not flow controlling. Can you copy and paste large volumes of text across without them getting corrupted? If you don't have any flow control set at all, try hardware; if you're on hardware at the moment, your cable may be dodgy, try software flow control. Failing either of those, try turning the baud rate of your connection down at both ends.
rieSha.
[…] If you don't have any flow control set at all, try hardware; if you're on hardware at the moment, your cable may be dodgy, try software flow control. Failing either of those, try turning the baud rate of your connection down at both ends.
+1 -- and strengthening JFTR: without working flow-control you’d need to drop the baud rate drastically when a 68k machine is involved: to 2400 bps or lower. Going “just a bit down” wouldn’t do the trick.
