SE/30 Green Fuzzies!
cbmeeks
I have this Mac SE/30 that was in pretty bad shape.  I'm going to recap it hopefully soon.
But after really looking close, I'm seeing this green "fuzz" all over the place.  Pretty much every where a capacitor was, a nearby chip has the corrosion all over the pins.
I'm really wondering if this board is a lost cause.  I'm sure with enough time I could probably fix it.  But some of those IC's look to be very hard to find.
The worst example are UB10 and UB11  (Sony audio).  But others are almost as bad including some of the VLSI chips.
This is my only SE/30.  I have three other classic Macs (SE FDHD, etc.) but this is the only '030 classic Mac I have.
I'm not so much disappointed about not having a '030...I don't really need the speed.  I just hate seeing a vintage computer become too damaged to repair.
What do you suggest?  I have the equipment to remove the IC's properly.  But is it worth the effort?  What would you do?
Thanks for any suggestions.
68krazy
I had those exact fuzzies on my SE/30, though not to the extent that you do.  Mine came off when I washed the board and the computer has worked great after a recap.
cbmeeks
FYI, I washed the board previously and scrubbed with toothbrush, IPA, etc.  I can't seem to get it off.
Bolle
Try vinegar as BGE said.
If that does not do it carefully use a tiny brass brush and get the corrosion off. Retin everything afterwards to seal the bare copper.
cbmeeks
I thought about vinegar actually but I was concerned it would cause some damage to traces, etc.  Is it safe to leave on the pins for a while?  How long would you suggest?
Also, why use a brass brush?  Curious on that one.
Thanks!
bibilit
I'm using the blue side of this kind of eraser to get rid of it... don't know if that can be found easily in every country.
Bolle
Thanks!
Brass is supposed to be pretty soft. You could probably use some other kind of metal brush as well. I did not try anything else - just sharing what I tried so far and it did work out pretty good.
mraroid
I think a toothbrush will also work.  You can buy soft, medium or hard when you buy a tooth brush.  I use soft.
I have used vinegar and I had no problems with it eating up the traces.  Try Apple Cider vinegar to give your SE/30 that fresh apple pie smell.  ;)
mraroid
Bolle
Toothbrush and the usual cleaning methods do fail for me if there is a lot of the green stuff hence the more aggressive approach using a light metal brush.
cbmeeks
Thanks for all of the suggestions!
So I tried vinegar and a dental pick.  I scrapped dozens of pins (very carefully) and I cannot believe the difference it made.  I'll post some pics soon.
I know I didn't get all of it.  Especially what might be lurking under the IC's.  But considering I cannot find many of these chips and I do not have spares, I think this is the best I can do at the moment.
I have to admit this board won't be my finest work.  But, if I can at least bring it back from the dead for a while...then it will have been worth it.
cbmeeks
As promised...more pics.
I think the vinegar and dental pick did the trick.
I had to order a few caps to finish.  Hopefully it will see the light of day by this weekend.
