SCSI2SD v5.5 error opening HID device
krishnadraws
I received my SCSI2SD v5.5 (external model). I'm plugging it in, via USB to my Macbook Pro. When I run scsi2sd-util, I'm getting "Error Opening HID device USB_04b4...". I've googled for answers and have not found anything. Can someone tell me what's happening and how to fix this error? Thanks!
krishnadraws
Thanks @LaPorta - I was able to move forward by not running the SCSI2SD-monitor utility.
Another issue: When I ran the standalone SCSI2SD-util, it recognized the SCSI2SD card just fine. I've set three 1.83GB partitions (emulating a Seagate ST225 drive), each with their own SCSI ID (1,2, and 3). I booted the SE/30 from a System 6.0.8 floppy and ran AppleHD SC setup. The program recognized the three uninitialized volumes. Currently I've been waiting several minutes for the first SCSI (1) volume to initialize / verify, with no end in sight. Is the initialization of a 2GB partition supposed to take some time? Or have I done something wrong? I've attached my SCSI2SD util settings.
krishnadraws
Solved! I used Lido 7.56 to initialize the three volumes. I recommend "Easy Setup", which formats each volume for the Mac and lets you assign a customized icon for each of your volumes.
MacFox
How did you run Lido? Asking because I recently bought a SCSI2SD v5.5 myself.  I’ve tried to copy Lido to a system floppy in the past but it wouldn’t fit.
