tanaquil
What do you do if a torx screw refuses to budge no matter how much leverage you use on it?
I just tried to pull my Classic out of storage, which worked on last check. When I turned it over to remove the screws, I saw some corrosion on the lower screw nearest the power outlet, and the inside rattled. I'm quite sure that's not a sound you want to hear. Sure enough, the machine when turned on doesn't even make it to the sad mac chime, and the video is scrambled.
One screw came out with no trouble, and it looks like I may never have replaced the other three after the last time I opened the case. But the rusted one is stuck fast, and rapidly becoming stripped by my many efforts to get it to budge. Do I have any options before I take it to the local repair shop to have them, I don't know, drill a hole straight through?
No matter how bad the inside may look, I'd like to try to save this machine. It was my very first mac, and I have a sentimental attachment to it, even though I have many better vintage machines from the same era.
