el_jeffe
I'm new to vintage computing and this is my first system. I thought I would try to de-yellow my beige Mac Plus. Before doing the case I tried the mouse and keyboard. All the keys looked good except for the spacebar.
I got some vol 40 stuff from the beauty supply place. Didn’t have a good source of sunlight as I’m in an apartment and there are trees so I decided to do it inside with the treatment only and no light. It worked well on the beige plastics after about 18 hours but it didn’t seem to work on the mouse button or spacebar.
So then I managed to find a space with some sunlight and I put them out and rotated after 30 min at which they were a bit lighter but not done. At an hour they were blotchy and platinum because I didn’t get the plastic wrap just right.
I scraped the mouse button lightly a bit with a hobby knife and the white stuff came off. Presumably the top layer of plastic. I’m thinking of trying some plastic polish that de-oxidizes. Worst case scenario I’ll see if I can find a keyboard or mouse that are in good shape or attempt to paint.
Thoughts?
Thoughts?
