Fixed my EtherWave Printer Adapter
dougg3
I recently tried to use mine after several years of it sitting around, and realized it didn't work anymore. No lights would come on when it was plugged in. It acted like it was completely dead. Thought I'd share my fix in case it helps someone else.
I opened it up -- very brittle plastics, by the way -- and found that the single through-hole electrolytic cap on the board had leaked out the bottom.
I cleaned it all up and replaced the capacitor. The original was a 560 uF 6.3V cap, but I didn't have that exact value on hand. I did have a 470 uF 10V cap though. Ehh, close enough. I'm probably a terrible person for doing that...oh well.
I plugged it in, and it still didn't work! No lights, nothing. So I got out my multimeter and traced things out. The input 12V power from the AC adapter comes into the bottom pin on that connector next to the cap. I tried to find anything else that had continuity with it on either side of the board, but I found nothing.
Taking a bit more time to investigate carefully, I noticed there's a via right under the connector that goes into the input pin of an LM3578A switching regulator (U8). I did more checking to make sure I wasn't confused, but I'm very sure that's where 12V is supposed to go on the board. It's the via just to the bottom right of the 8 in the U8 silkscreen text. The cap goo must have rotted it out on the top side of the board. I can't see it because it's underneath the connector, but I have no other explanation. That via is very close to the cap.
There's no easy way to run a bodge wire from the connector to the other side of the PCB. It's pretty cramped in there. So instead, I de-pinned the 12V input wire from the connector, cut off the crimped pin, brought it out separately to the other side of the PCB, and soldered it to a convenient place where it would have a lot of mechanical support. Don't mind my dirty-looking solder joints on the replaced cap. I fixed them afterward.
Now it works great again. I had to superglue the case shut because of the plastic breaking like crazy inside of it.
If you have one of these, you should open it up and recap it before it's too late!
Mk.558
I recapped both of mine but they are still sketchy about routing TCP traffic, and appears to have issues with DNS for some weird reason.
Mine takes two 6v3 470uF and one 25v 120uF cap. Weird.
I still seriously think emulating one of these in a more modern specification is something we're going to have to do at some point.
dougg3
Interesting! I haven't messed around too much with TCP stuff on mine. Maybe it's a software thing...
What version do you have? I am recalling that there was a version that took power from the ADB port. I think it was called EtherWave Mac/PB Adapter. Is yours that version? Mine only has a barrel jack connector. Is it possible that's the difference?
Iesca
Ah, maybe I should open mine up pre-emptively. Is the case just closed on some plastic pins?
dougg3
To be honest, it kind of crumbled apart on its own when I looked at it, but there are two screws right near where the cable comes out of it. I think the intended way for it to open is you have to remove those two screws, and then it pops open. There are definitely some plastic pins involved too, but they broke on mine.
I wouldn't be surprised if the standoffs holding the screws in will break. It's really brittle plastic...
Iesca
Hmm, well, the plastic on mine seems to be in much better shape, as removing the screws doesn't seem to be enough, and no pulling or tugging seems to release the top, just some give on the side of the screws.
EDIT: Ah-ha, just have to gently apply pressure where there's room to wedge to release the plastic pegs.
Iesca
Here are a couple photos, for reference. Amazingly, everything's intact, plastic-wise!
Iesca
And one of the top of the board, just for good measure. Looks like mine doesn't have any electrolytics, so that's good to know. Guess I can just put it back together! Mine is technically the AAUI Transceiver, so perhaps it's a different design altogether.
dougg3
Ah yes, there are a lot of different EtherWave products. The Printer Adapter that I repaired is a LocalTalk to Ethernet bridge rather than the AAUI transceiver one. It's still interesting to see the inside of it though, so thanks for sharing!
