michimartini
In my Mac-Plus the connector going from the yoke to the analog board has been fried to a crisp due to intermittent contact. I tried to clean and tighten the charred remains of the contacts, but the horizontal width is never quite stable because there is no more any firm and low resistance connection on the hot horizontal deflection pin.
So in my desperation I resorted to desperate methods
But that's just not proper. So after much searching I came across the correct parts on Mouser: It is a 1/4 inch (6.35 mm) pitch Mate-N-Lok connector. The one I found there has the retention latch on the narrow sides instead of the broad side like the original, but this should not matter.
board connector
mouser part number: 571-350793-1
manufacturer part number: 350793-1
cable connector
mouser part number: 571-350779-1
manufacturer part number: 350779-1
I am writing this down here so all that searching can be useful for someone else who has the same problem. Even if I prove to be too lazy or stingy to actually order the part, someone else might want to do it.
board connector
cable connector
