Quicksilver won't boot from Leopard DVD
woopud
I have this DVD with Leopard on it but my Quicksilver won't boot from it, I even tried coping the DVD to my second hard drive and boot from there but it won't. Any ideas ?
Bert
Anonymous Freak
Well, assuming you're referring to the 733 MHz QS in your sig, unless you use one of the OpenFirmware hacks, it won't work.
The Leopard DVD checks processor speed, and if it is less than 867 MHz, it fails to boot. There are simple hacks that basically involve modifying the speed OpenFirmware reports to bypass this check.
One utility to do this for you can be found here.
iMac600
Ah... a LeopardAssist question, I may be able to field this one since I develop it. Well I did up until last week or so.
Very simply LeopardAssist is problematic on QuickSilvers, they don't always react well to having their firmware tweaked. You may be able to get away with just simply selecting "None, I will hold down a key" in the configuration dialog when it comes to selecting a boot drive. Proceed as normal and restart when prompted.
Then just hold down Option on boot to bring up the boot manager, from there you should be able to select the installer drive.
We're running through this over on the LeopardAssist forum at the moment.
http://www.mac.profusehost.net/forum/index.php?topic=50.0
Unfortunately the only test system I had for LeopardAssist was the Sawtooth G4. Version 2.0 which was in production had a new way of communicating with the NVRAM which was almost foolproof, and would have corrected these issues (most likely). Unfortunately the Sawtooth G4 used to develop it came to an abrupt end earlier this week and therefore the app can no longer be tested- in turn the app may officially cease development some time next week.
woopud
Okay, so i typed in those three lines as described in the link in the previous post but then what do I do ? After hitting return after the third line how do I reboot ? just hit the reset button ?
Bert
woopud
Well, I tried something else with no luck either...
I copied the installation DVD to a harddrive and the put this in a FireWire harddrive enclosure, when I hold down the "option" key while booting it will let me select the drive with the installer and it will start but then it will just keeps spinning on the gray screen with the apple logo and spinning wheel.
Bert
