techstep
Hi All,
I recently bought a Quadra 950 from someone on these forums. The computer was packed by UPS in a good box with plenty of bubble wrap and arrived without any external damage.
However, the computer just doesn't successfully power up. The seller says it worked perfectly before shipped. When turning the key to the 'run' position or when pressing the soft power button on the keyboard, the power supply starts to engage, and the fan spins for 1-2 seconds, and then immediately turns off. I also vaguely hear a hissing from either capacitors or an internal transformer?
Here's a video for illustrative purposes:
https://www.dropbox.com/s/0u2cc1kiici74e1/Video Dec 07%2C 9 59 50 PM.mov?dl=0
I've tried unseating all peripherals, removing/reinstalling all the removable memory/vram, disconnecting all cable connectors to the logic board, etc.
I've measured the power supply voltages where I could. Soft power 5V is there, 12V is on target, but the 5 volt rail coming out of the hard drive connector to ground measures 0.55 volts, leading me to believe the issue may lie in the power supply.
Anyone seen symptoms such as this before? I'll see if I can borrow a Quadra 950 Power supply from somewhere to test my suspicions, but would appreciate any other troubleshooting tips/insights you guys recommend.
Cheers!
Cheers!
