Some of you may recall the Power Mac G4 Quicksilver I picked up for the fantastic price of free not that long ago. It was destroyed by a student who fiddled with the voltage regulator, connecting a 110v power supply to a 240v line which vaporised the power supply and sent a deadly surge to the logic board.
Not even that will keep this Quicksilver down though. Presenting Project Silvertooth.
This is a true cut and assemble of three G4 systems of various series, the Sawtooth, the Gigabit Ethernet and the Quicksilver. The aim of the project is to assemble a machine that will run using a standard ATX power supply with minimal modification, offer comparable speed to a factory Quicksilver (if not exceeding it) while creating an all round funky machine.
I've often been asked why I would undertake such a challenging, time consuming or, as some have suggested, stupid project. Aside from the fact it will contribute to my electronics certification semester grade, it's also in the typical spirit of the 68kMLA. The machine is newer than most of our vintage Macs here, but it's still a system that, despite being abused all its life, will live again and see active service very soon.
I shall aim to keep the thread up to date on the project, with photos, as it progresses.
Cheers
- Michael
The Gigabit Ethernet logic board cost me $63 from Apple-Bits in Melbourne. Everything else on the list has been free or donated to the cause. I expect to spend no more than $100 on the project to get it running at full operating capacity. To clarify the need for some of these extra parts...ALREADY HAVE
- AOpen 400w ATX PSU
- Quicksilver 733 CPU Module
- 1GB SDRAM (PC133)
- nVidia GeForce2 MX 32mb
- LG SuperMulti Recorder
- 160GB HDD
- Quicksilver Case
- Sawtooth Rear Panel
- 12v CPU Booster Cable
- 4-Port Firewire Card + 1 Internal
- Bluetooth Connectivity
- Gigabit Ethernet Logic Board
- Mac OS X Leopard 10.5
- LeopardAssist 2.0 (for booting 10.5 on it)
- Imagine BootX (for creating a custom boot screen)
NEED
- PSU Extension Cable
- DIP Switch (Highly RECOMMENDED)
EXTRAS
- WiFi Card
- USB 2.0 Card
A Mac OS X Leopard 10.5 install disc has also been kindly donated to the cause by the school's IT administrative department, so a thank you to them for supporting the project to see their old server back in action.DIP Switch. Soldered into place on the logic board, this will allow changing of the frontside bus speed either up or down depending on switch configuration. I hope to achieve 133mhz or close to that amount, hence the need for all PC133 RAM.
12v CPU Booster Cable. Quicksilver CPU's used an extra 12v supply line to power the CPU module, similar to the Pentium 4 extra power connector. The addition of a booster cable connected to ground lug 4 provides the CPU with the 12v it needs to operate. Most CPU upgrade cards from PowerLogix and Sonnet also use this method.
PSU Extension Cable. This allows me to connect the ATX power supply to the Apple logic board, but also gives me a secure option to make the necessary output conversions for the power supply to work with the logic board. If the connections fail, then it's no big loss, these extension cables are quite cheap.
Cheers
- Michael
