Superdos
The other day I picked up a Power Computing Power Tower Pro 250 after being tipped off that it was sitting without a pricetag on a shelf at the thrift shop.
Went to the back, got a $20 pricetag on it, went up front, hey, it's 50% off day! Paid $10 and left. Sat for two days. I suspected it was rocking a PPC 604e 250MHz as advertised, I knew it was decked a bit with RAM but I did not know how much, and that it had 3 hard drives, two graphics cards, USB and FireWire cards, and an Adaptec SCSI card with external header which I could only surmise was for a Zip or Jaz drive (of which I do have.)
It was way more decked out than I could have hoped for.
- 384MB of 60ns RAM, interleaved,
- 2GB, 6GB and 18GB hard drives,
- a TwinTurbo 128M8 alongside a ProFormance III 16MB (which turned out to be dead!)
- upgraded Apple-branded 12x SCSI CD drive,
- and to top it all off, an XLR8 G3 400/1M CPU card!
I think I did rather well for $10, and I think someone loved this machine a whole lot in the 90s. I have it running 9.2.2 right now, really helps with the G3 upgrade installed.
So far I've removed the 2 and 6GB drives, leaving only the 18GB, replaced two 80mm fans (CPU and rear exhaust) due to dust-induced death rattle, redid the thermal compound on the XLR8 card, installed my Rage 128GL 16MB from my 6500/275 and installed a Realtek 8139C 10/100 clone from SMC and modified the driver from Realtek to see it as the correct card as per the manual that came with the driver itself! (had me use General Edit Lite to do it.) May be switching this with an MPX card with proper 10/100 indicators, but this seems like a better deal than paying money for an AsanteFAST card with a DEC tulip chip on it. ALso dropped in the SCSI zip drive from the 6500, which I've also stolen the RAM from to up it to a total of 576MB with another 128MB stick on the way to bring it to 640, fully interleaved.
Currently I have a 73GB IBM eServer pSeries rebranded Hitachi Ultrastar on the way, SCA, and appropriate terminating SCA to wide adapter as well. I'm working out whether I want that drive to be on the Adaptec card (25MB/s transfer rate max) with the CD/Zip on the internal bus, or vice-versa. Memory serves that the double bandit Macs had some issues with the PCI slots and different cards, something something cards that needed something or other needed to go in the top slot for each bus (so slot 1 and 4 from the top-down). Otherwise I"ll just leave the original drive as-is in place and use this on the bus with the CD/Zip as the original was.
Also contemplating SCSI cards for replacements, PowerDomain 2940's are pretty expensive still though, and turning a 2940UW on hand into a PowerDomain Mac card seems to be too tedious a task. Also following through on PCI SATA; I have a Sonnet SATA card somewhere from when the GigE dual G4 450 in my mom's closet was once fitted with a SATA drive, this might also turn out to be a viable option. I still have some older 80-gig drives with molex power, so that'd work. The plan is to dual-boot 9.2.2/Debian PPC on this with seperate drives, if that's even plausible. Also awaiting SOMETHING good to come out of Haiku/PPC, but that's still STILL in the baby stages as far as anything is concerned.
Graphics card? not sure where I'm going there. the Rage 128GL is fine for now, something a little heftier would be nice later on, be it a modded PC Radeon card down the line or what have you. I have a PCI 9250 256MB, but I don't think there was ever a 9250 for Macs outside of AGP. if anyone has any info on this, let me know.
And lastly I'm planning on finding a proper PSU swap. I understand that these are normal ATX supplies? if that's the case, I have a HIPRO H-29538 400W supply I can just drop in, it has PIII and ATX12v connectors on it but it's right as rain otherwise. and, the fan isn't loud as all living dead like in the current!
Pics of this magnificent beast can be found here -- little yellowed on the front, but I think it'll clean up nice.
