PowerBook multi-Duo
Franklinstein
With the purchase of this curiosity, I feel that it may be time to re-think the whole eBay thing.
This machine was advertised as a Duo 280. I figured cool, I don't have one of those yet, go for it. $15 plus $15 for shipping later, it's here, and it's not a 280. Sure, the bottom says 280, but it's not. This thing would make Victor Frankenstein cringe. It has:
Bottom case and hard drive from a 280
Logic board from a 230
keyboard and display from a 210
The display hinges are weak, and the keyboard is the worst example of a Duo I've ever used. It's never a good thing when one must pound or continually press the hell out of a key to get a response from it. Otherwise, it functions well enough, and came with a power supply. It's going to be a part donor when I get home, though; no sense in keeping this monstrosity in one piece. I already used the 320MB hard drive to upgrade my 540c, and I'm sure I can find a use for some of the case parts.
This is the worst machine from eBay since the "fully loaded" Lombard in "great cosmetic shape" that was missing the processor heat shield and hard drive caddy, had a half-functional keyboard with half of the key caps rubbed off, an "X" carved into the display plastics (probably by some kid), a dead battery, and a flaky CDROM instead of the advertised "combo" drive. Jerks.
Okay, enough negative. I bought a Buffalo WLI-CB-G54S today, and, with AirPort 4.2 under 10.3 on my Lombard (don't know about 10.2, I'll try my WallStreet later), it works flawlessly with no extra drivers. Now I can use my aged PBG3's on wi-fi under OS X. Great choice for 802.11g on any CardBus-compliant Mac, except it won't work under OS 9 (but no 802.11g, even Apple's own AirPort Extreme, works properly (or at all) under 9).
I already have three older Buffalo WLI-PCM-L11GP that I use on older machines. If you find any of these older cards, I suggest buying them. They work wonderfully on any Mac with PCMCIA cards, under System 7, OS8 or OS9. I can run my PB190cs wirelessly if I had it here with me. OS X needs drivers to use this card, though, which is one reason I bought the WLI-CB-G54S.
No other cool Mac acquisitions. There's a place downtown where I could buy a couple of Amiga 500's, so I've been mulling over the thought of doing that eventually. I don't have any Amigas yet.
macdownunder
Sorry to hear about your bad experience.
...and the keyboard is the worst example of a Duo I've ever used. It's never a good thing when one must pound or continually press the hell out of a key to get a response from it.
In recently getting all my Duos out for testing, I found that most of them (in fact all except the 2300c) had this problem. I'm guessing that the contacts oxidize more easily on these models.
In my case, with a little persistence I managed to get all the keyboards working properly again.
Regards,
Macdownunder.
Bunsen
Admin-Witchfinder-General
Bottom case and hard drive from a 280Logic board from a 230
Give my creation .... LIFE!!! {insert thunder crack}
Hey Macd: what did "a little persistence" consist of? Just lots of pounding, or the whole strip down and clean routine?
I have this crazy idea here he goes again that a 12" iBook keyboard might just fit (physically).
macdownunder
Hi Bunsen,
A bit of both. Most of the keys were stiff. Where "pounding" (ie continual gentle pushing up/down) didn't work (and mostly it did - eventually), taking the keyboard out and cleaning, working the keys etc. did the job. I didn't need to disassemble the keyboards completely.
Regards,
Macdownunder
aftermac
Duo Keyboards are notoriously crap. I've owned 3 Duo's (270, 280, 2300) and the keyboards were crap on all of them.
My 2300, the only Duo I still have, has the wrist rest from an older Duo. It has a trackball instead of a trackpad... which I prefer.
