LCGuy
LC Doctor/Hot Rodder
One of my mates recently picked up a Wallstreet and a Lombard at a swap meet which we're working on, they both have issues of their own, and we could use some help...
Wallstreet: The Wallstreet actually runs really well, apart from a couple of problems - first, the internal display doesn't work. Its not just an issue with the backlight, nothing comes up on the display at all. We think it could be an issue with the display cable either being damaged or disconnected, but we can't really explore that option at the moment, due to the next issue that we need help with with this machine: one of the screws that holds the heat shield on is stripped. We've tried everything short of drilling it out (which neither of us really want to do with a PowerBook), but no matter what, we can't get it out. I've looked at the service manual, which has confirmed my theory that the only way into the Wallstreet, like most PowerBooks, is through the top, through the heat shield.
Lombard: The Lombard has its own issues - firstly, the internal CD-ROM is dead. I have a spare laptop DVD burner here which I've put in it, which was pretty much straightforward. The trouble is that although the drive works, and I can mount discs and access files on them, I can't boot from it. I know this drive can boot a Mac - I have used it to boot my tray load iMac into both OS 9 and OS X. It has a similar issue with a hard drive I've installed in it. The machine came with its original 4GB which works fine, but is a little small. So I installed a 20GB Toshiba that I pulled out of a Compaq. Under both OS 9 and OS X, I can format the drive, I can mount it, and I can read from and write to it, but no matter what, I can not get the machine to boot off it. I've tried formatting it several times in both OS 9 and OS X and I've also tried zeroing it. I have since tried the drive in another PC laptop, and I had no issues installing Windows XP on this drive and booting off it. But no matter what, the Lombard will not boot off it. I've also tried putting the drive into my PowerBook 1400, which won't even recognise the drive. The Lombard has no issues with either the original 4GB, or a non-Apple 2GB drive that i have lying around, so clearly its something to do with the drive. At this point I'm thinking of just buying a new drive for it.
So thats that...thanks in advance
