dcr
So, out of morbid curiosity, I took a look at my PowerBook 5300ce last night and, well, the good news is that it boots. Hard drive doesn't work; just clicks. Maybe it's repairable; maybe not. Either way, the hard drive situation can be resolved. The battery is no good. I don't know if that can be replaced/rebuilt or not, but the PB runs off the AC adapter, so that's good. Probably there's stuff that needs to be recapped.
Biggest problem is, of course, the plastics. The bottom is mostly okay but the top is a lost cause. The common problem, as I understand it, are the hinges and those are definitely an issue.
I thought I had another, possibly a 5300cs, but I didn't see one around and my spreadsheet doesn't show one, so maybe this 5300ce is a one and only. So, that leaves out the possibility of trying to Frankenstein a functional machine. It seems like it would not be worthwhile to try to buy a parts unit with good plastics because I imagine the plastics are going to break eventually anyway.
I know there were threads in the past on trying to 3D print replacement parts or custom case ideas, but, from a quick search, it looks like none of those ideas panned out. Just curious as to whether anyone has more recently come up with any feasible solutions for re-casing these machines?
